Results 1 to 4 of 4
Thread: P1063 fault code crafter
    Feb 2019
    TR
    Hi Friends,
    I have 2011 Model years Crafter LWB 120 KW Bjm Engine minibus,
    Yesterday, i driving minibus, i see the cluster display glow plug light flashing and limp mode minibus, stopped engine. I start the engine problem fixed 3 minutes later glow plug light flashing and limp mode stopped engine, I goes to bosch diesel service, voach diesel service change fuel filter and road test forblem not fixed, bosch diesel techinician see the my minibus engine, tachnican says "your engine fault fuel pressure sensor", bosch kts computer connect the my minibus, bosch kts see the p1063 fault code. Bosch technican change the VAG 076906051 number fuel pressure sensor. I driving my minibus road test on 30 minutes and problems fixed. One day later i driving minibus i see the cluster display again glow plug light flashing and limp mode stopped engine i goes to bosch diesel service, service computer connct the minibus, bosch kts computer see the P0087 Fault code and technician change the VAG 057130764B number sensor. I driven the minibus road test 30 minutes, problem fixed.
    do you have any other idea about these fault codes P1063 and P0087?
    Best Regrads.
    SM-G610F cihazımdan Tapatalk kullanılarak gönderildi
    Feb 2019
    TR
    Hi Friends,
    One day after the problem was solved, the minibus again gave the same error, this time the electrician in the bosch service center checked the vehicle for 3 hours in sequence, checking the wiring harness on the engine. the sensor on the back of the cable and socket has detected that the measurement of the error. repaired the cable in the wiring harness and replaced the socket. The problem's been solved.
    Feb 2019
    Melbourne Aust.
    Great to get a quick fix on that
    Just for future reference...did they tell you what the P1063 and P0087 error codes actually were ?
    What was the actual fault found ?
    2009 Crafter 35 Motorhome
    2.5 TDi Auto
    Taking the Road Less Traveled
    to Folk & Blues Music Festivals
    Feb 2019
    TR
    Quote Originally Posted by Lance View Post
    For fast solution;
    Firstly
    Replace the fuel filter,
    Secondly
    check fuel pump and connections in fuel tank
    as the third
    check injector and fuel pump connections
    fourth;
    Have the injector return test.
    fifthly;
    check the connections of the fuel pressure sensors
    sixthly
    replace and test the fuel pressure sensors respectively
    fault finding procedure at the bosch service center
    Best regrads.
