Hi Friends,
One day after the problem was solved, the minibus again gave the same error, this time the electrician in the bosch service center checked the vehicle for 3 hours in sequence, checking the wiring harness on the engine. the sensor on the back of the cable and socket has detected that the measurement of the error. repaired the cable in the wiring harness and replaced the socket. The problem's been solved.
SM-G610F cihazımdan Tapatalk kullanılarak gönderildi
