My Van
Volkswagen Crafter 35 2.5 Tdi. 163 Hp. LWB
6 Speed Manual Gearbox.
2.5 tdi. Bjm engine code
16 +1 Passenger
double air conditioning
Tyre front 235/65R16C 121R
Tyre rear 235/65R16C 121R
SM-G610F cihazımdan Tapatalk kullanılarak gönderildi
Hi Everyone;
I am a new member in this forum
I have a crafter van in 2010.
The engine of my van BJM Engine 163 horsepower.
I don't know the model of transmission and its axle my van.
What is the oil used for my van engine, gearbox and axle.
How many used oil my van engine, gearbox and axle.
I didn't find a document on this topic in the forum.
I did not get clear information about this van from the repairmen in my area.
Thanks for your help.
Best regrads.
My Van
16 +1 Passenger
The engine oil with VW507.00 specs, 9L of it.
The gearbox oil 75W80 GL4+ 1.5L fill capacity, many oil companies say go to dealer and don’t recommend any their oil. Penrite says Transgear 75W80. LiquiMoly should have one for gearbox as well.
Rear diff is 1.6L dealer only.
I called dealer and I did not get a clear information.
Dealer says you used axle oil febi blistein oil number 32590 and gear box oil febi bilstein oil number 21829. Dealer says could not give clear information about capacity.
Febi bilstein oil 32590 = SAE 75W-90 GL-5
Febi bilstein oil 21829 = SAE 75W GL-4
Best Regrads.
Mate, he's given you the information.
1.6 litres of oil and it's dealer supplied.
This will give you the VW part number for the oil.
rear axle Crafter (CR) 2011 year Volkswagen EUROPA
Thanks brad;
I found from the local oil supplier axle oil Lique Moly Hocleistungs Getriebeöl GL 4+ 75W90, oil spec. VW 50150 (G50) 2 liters, and gearbox oil Lique Moly Top Tec 5100 75W MTF GL 4, oil spec. VW G 052 178, VW G 052 512,VW G 052 726,VW G 060 726,VW G 070 726 .
Best Regrads.
