Sounds good, that non slip flooring is great.
Got any photos with the side panels installed?
From next week we have stock again as keep running out. We will start supplying VW direct so retail sales will stop then.
L3/MWB Floor
L3/MWB Wall panels
L4/LWB Floor
L4/LWB Wall panels
Wheel arch boxes are coming so are Rear window security screens
Floors are all 2 piece in 9 mm birch plywood with non slip surface
Tie down pints cut out. floor is resistant to water, oil, fuel and light acid
Wall panels are in6.5 mm birch plywood with polypropylene coating for easy maintance and
no fluids can penetrate the wood. all panels come pre drilled so NO guessing where the screws need to go
or touching any electricals
This aeesome van should bring you lots of joy. It drives like a dream. Well done VW
Jan Eveleens
Motexion
2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
Are there ceiling panels available?
2018 Crafter Runner
2012 T5.1 6sp manual.
2024 Crafter Auto
