Results 1 to 1 of 1
Thread: New Crafter 130kW Maintenance Info
    Adelaide hills, SA
    Spoil alert, many will find this boring.
    In this thread, I'm going to post some basic info on basic maintenance and parts. This thread will be frequently updated.
    CRAFTER 2021 4MOTION
    ENGINE OIL CHANGE
    Oil filter ......... Mann HU7020Z
    Air filter ......... Mann C29036 or Wesfil WA5546 (Burson, Auto Pro)
    Cabin filter ..... Mann CUK26009 or Ryco RCA270M
    Engine oil ....... Fuchs GT1 PRO C-3 ......... 9.4L (103kW engine takes less than that)
    Sump plug ..... M14x1.5mm
    AUTOMATIC TRANSMISSION
    Oil/ATF ........... Fuchs ATF6008 ............... 7.8L (dry fill)
    MANUAL TRANSMISSION
    Oil .................. Fuchs SINTOFLUID FE75W.....3L
    COOLANT
    Capacity ..... 14L
    Use genuine coolant, in emergency for top up, you can use distilled/demineralized water if you don't have coolant.
    Then as soon as you can, adjust the coolant concentration to 50%.
    ADDBLUE ..... 18L capacity
    BRAKES
    Front brakes
    Pads ..... BOSCH
    Discs ..... DBA3730E ..... 303mm ..... option 1LA, 1LB
    Rear brakes
    Pads ..... Pagid T2733, BOSCH
    Discs ..... DBA2777E ..... 300mm ..... option 1XO, 1X1
    Also available are DBA2777S (slotted)
    Rear brakes are the same as on Amarok V6
    ELECTRICS
    Battery ..... DIN85LH AGM
