Ignition key wouldn't turn..........
Got into the van this morning to move it and the key refused to turn.
I figured the most likely was steering lock jammed........wiggled and waggled the stg wheel and made no difference.
Then had horrible thoughts of a very expensive ign swith replacement.
So what do ya do ?
Ya turn to Google.
Found a report of a similar instance where a flat battery was the issue.
Nothing left on that I was aware of but decided to mcheck the battery anyway.........
......... 8.8v,,,,,,,,,,,,,![Confused](https://www.vwwatercooled.com.au/forums/images/smilies/confused.png)
Charge the battery and all is good again.
Got me a tad confused but I guess it everything shuts down at a particular low voltage.
My problem is solved now other than finding what drained the battery down so low
but hopefully this may help someone with a the same problem.
Further to this possible battery drain............
There is a very slight vibration sensation from the centre dash area around the radio/heater control area.
It feels like a gentle fan running somewhere but as far as I can tell there is nothing running or switched on.
My hearing is crap so I just had my wife out in the van and she tells me there is a 'hum' coming from the floor area around the battery..
Further investigation required I feel...........
Hi Lance
the reason why the car is running out of battery can be caused by the air conditioning compressor and auxiliary water pump.
Best Regrads.
SM-G610F cihazımdan Tapatalk kullanılarak gönderildi
Air/con was not on, and by auxiliary water pump.... do you mean the pump in the motor home area ?
That is run from a separate battery.
Additional water coolant pump number 28.![](http://www.vwwatercooled.com.au/forums/images/imported/2019/03/1c7404c890e38b9e51f78899c6c43903-1.jpg)
There is a very slight vibration sensation from the centre dash area around the radio/heater control area figure number 8A. (servomotor for distribution
flap)![](http://www.vwwatercooled.com.au/forums/images/imported/2019/03/71ffefc6cce45addc1a1acbe8034c9b7-1.jpg)
Your hearing is crap so I just had your wife out in the van and your wife told you there is a 'hum' coming from the floor area around the battery.. Fuel delivery sender may be![](http://www.vwwatercooled.com.au/forums/images/imported/2019/03/1b5d5674803ad7e89e28b65b1f73dc82-1.jpg)
I think I might've found the 'hum'.
This vehicle is a motorhome with an auxiliary battery fitted under the left seat.
I think the hum may have been the dc/dc charger for that battery.
The vibration in the centre dash has disappeared now but was present with no keys in the ignition, so I don't know where anything would have been getting power.
I'll let things go now and see what happens.
Additional water coolant pump number 28 ?
Didn't realise that was there.
Thanks again for you time.
Do you have a link to a parts catalog for the 35 ?
- You may not post replies
- You may not edit your posts
Forum Rules
