Results 1 to 8 of 8
Thread: Ignition key wouldn't turn..........
    Feb 2019
    Melbourne Aust.
    Got into the van this morning to move it and the key refused to turn.
    I figured the most likely was steering lock jammed........wiggled and waggled the stg wheel and made no difference.
    Then had horrible thoughts of a very expensive ign swith replacement.
    So what do ya do ?
    Ya turn to Google.
    Found a report of a similar instance where a flat battery was the issue.
    Nothing left on that I was aware of but decided to mcheck the battery anyway.........
    ......... 8.8v,,,,,,,,,,,,,
    Charge the battery and all is good again.
    Got me a tad confused but I guess it everything shuts down at a particular low voltage.
    My problem is solved now other than finding what drained the battery down so low
    but hopefully this may help someone with a the same problem.
    Feb 2019
    Melbourne Aust.
    Further to this possible battery drain............
    There is a very slight vibration sensation from the centre dash area around the radio/heater control area.
    It feels like a gentle fan running somewhere but as far as I can tell there is nothing running or switched on.
    My hearing is crap so I just had my wife out in the van and she tells me there is a 'hum' coming from the floor area around the battery..
    Further investigation required I feel...........
    Feb 2019
    TR
    Hi Lance
    the reason why the car is running out of battery can be caused by the air conditioning compressor and auxiliary water pump.
    Best Regrads.
    SM-G610F cihazımdan Tapatalk kullanılarak gönderildi
    Feb 2019
    Melbourne Aust.
    Air/con was not on, and by auxiliary water pump.... do you mean the pump in the motor home area ?
    That is run from a separate battery.
    Feb 2019
    TR
    Additional water coolant pump number 28.
    Feb 2019
    TR
    There is a very slight vibration sensation from the centre dash area around the radio/heater control area figure number 8A. (servomotor for distribution
    flap)
    Feb 2019
    TR
    Your hearing is crap so I just had your wife out in the van and your wife told you there is a 'hum' coming from the floor area around the battery.. Fuel delivery sender may be
    Feb 2019
    Melbourne Aust.
    I think I might've found the 'hum'.
    This vehicle is a motorhome with an auxiliary battery fitted under the left seat.
    I think the hum may have been the dc/dc charger for that battery.
    The vibration in the centre dash has disappeared now but was present with no keys in the ignition, so I don't know where anything would have been getting power.
    I'll let things go now and see what happens.
    Additional water coolant pump number 28 ?
    Didn't realise that was there.
    Thanks again for you time.
    Do you have a link to a parts catalog for the 35 ?
