Results 1 to 4 of 4
Thread: Crafter turbo problem
    Feb 2019
    TR
    Hi friends
    My minibus Crafter CR 35 LWB BJM Engine 2.5 Tdi 163 Ps.
    There is a strange problem in the car, when the car is driving on the road, it is as if it is drowning in the range of 2500 -3000 rpm, the engine is shaking. My mechanic here said that there might be a problem with the fuel, the rail sensors of the vehicle were all tested with new ones, the injectors were all tested, the maf and map sensors were tested, the problem in the car did not improve, we started the car, while running at normal idle, the engine does not pass 3000 cycles and shakes the engine. I press and pull again the same, the clutch pedal sensor was tried with the new problem again the same, the car never burns the malfunction lamp, and the car brain does not slide out, when I say the car this day, when I pull the vacuum hose that goes to the vestgatene of the turbo, I hit the gas normally, the car makes 4000-5000 cycles and it works normally, I follow the vacuum hose of the turbo, the car stays at 3000 rpm and the engine shakes. There is no fuel leakage in the car, does anyone have an idea about it?
    SM-M315F cihazımdan Tapatalk kullanılarak gönderildi
    Feb 2019
    TR
    Hi Friends
    I have changed N75 valve proble is solved.
    Feb 2019
    Melbourne Aust.
    Great to see another problem solved.
    I've saved this to the memory banks in case it crops up for me later on.
    What mileage does your Crafter have ?
    2009 Crafter 35 Motorhome
    2.5 TDi Auto
    Taking the Road Less Traveled
    to Folk & Blues Music Festivals
    Feb 2019
    TR
    I have 2 crafter minibus
    First Crafter 2010 Model CR35 LWB BJM Engine 2.5 Tdi 163 Ps. 524.000 kilometer = 325598 miles.
    Second Crafter 2011 Model CR35 LWB BJM Engine 2.5 tdi 163 ps. 622.000 kilometer = 386492 miles.
    N75 changed to second crafter..
