looks like a stuffed transmission oil pump might be the cause. will post results a week after tests
Tho the Crafty has since been towed to sinclaires, what is the problem?
Car pulls out of a yard and shows "F" on the dash and wont engage the gears. Try to restart, now the "N" flashes and wont restart. Looking for possible failures, has done this twice now
check the oil level (hydrolic) of the shiftmatic.
I am sure it is to low.
Had the same issue a couple of weeks ago at work
Hi,
I appear to have the same problem, as yours.
I found the hydraulic pump had failed.
I have replaced the pump but can not get any voltage to the new pump.
Still shows engine icon and F on the dash.
How did you get yours fixed?
Did you have to get the engine management computer re-programmed?
I also replaced the hydraulic and gearbox oil.
Was it the filter on the shiftmatic gearbox?
Col
