I’m not sure if it’s possible, but I’d use additional camera/rear view mirror combo for that.
G'day all,
Is there an easy way for me to add a switch in the cab that tricks the system into thinking I'm reversing so I can see the rear camera view while driving forwards?
I've had a look behind the display, and in the gear shifter and there's nothing that's obvious to me.
I'd rather use the existing system than adding an aftermarket camera.
Thanks in advance for any tips!
Hello The reversing camera in your vehicle receives reversing + 12V electricity and triggers the reversing screen on your vehicle, and the reversing screen turns on in your multimedia, reversing the reversing lights on your back, so that you can watch the back of your vehicle on the road, you can cancel it from the reversing lights + 12V from your back of your car. Except for + 12V, you should pull the power cable and connect a new AC shut-off switch to your vehicle. A competent electrical specialist can do this
Best regrads
SM-M315F cihazımdan Tapatalk kullanılarak gönderildi
