DPF blockage occurs both from soot, and from oil ash. I'd HIGHLY recommend anyone with a DPF gets a Provent or similar high quality oil blowby seperator, and plumbs it inline from the tappet cover and inlet , as there is a lot of oil vapour entering the stock VW inlet. Since hobbling my oil blowby via a Provent, then into the exhaust ( illegal ) I've not had a single regen happen that I'm aware of. It's probably doing them automatically every several hundred kms or whatever the minimum default is, but before I was getting an obvious, higher idle one every week or so. Has to be something in that. Also, you HAVE to drive the thing hard enough to get the EGT's up, and thus burn off the soot from the DPF. An EGT gauge is a valuable tool there, for now I drive at higher revs, and avoid off boost sub 1800rpm at all times. I never hit 6th on the freeway, and am often in third at 50-60kph. Lugging it along sub 1800rpm is producing a TON of soot. Not sure how good the DSG box is at doing this.
From what I understand of the actual makeup of the VW DPF, blowing it out in reverse will be a temporary fix at best, and if you do indeed need to start getting DPF's replaced, would highly recommend looking into DPF delete tunes which give both more power AND more economy, or upgrading to a decent aftermarket DPF from specific manufacturers such as Donaldson. This is going to be a huge issue for the current gen of diesels, and it's why I've been going on and on about Provents for some time now.
