Results 1 to 2 of 2
Thread: Auxiliary Fuel Filter Fitment.
    Oct 2013
    I've had the filter for months, been putting it off, cos I'm not sure/comfortable, with cutting that 8mm nylon fuel hose...!
    Any tips...?
    The plan is too use two fully banded fuel hose clamps on each hose that slips over the nylon, as the nylon hose tails wont have any barbs to help hold the hose from slipping off. I'm fairly sure its only low fuel pressure from the tank to the Mechanical fuel pump, on the motor.
    Are ferrels, or something similar available to slip onto the cut Nylon Fuel Hose...?
    Thanks.
    Steve.
    Adelaide hills, SA
    Hey Steve, how did you go? I’ve a very comprehensive EFI hose repair kit and there are just straight nylon tubes as joiners with hoses and hose clamps that you crimp, so as long as you use the EFI hose clamps you’d be ok.
