AdBlue tank always refilled on time, never went bellow half. The warning on the dash came when the adblue tank was near full. The top-up took less than 1L of adblue.
The Crafter has still 1 year warranty remaining, so it's booked at the Southern Volkswagen for 17 February to rectify the problem.
There's no fault anywhere in the system when scanned with the VCDS.
Sent from my SM-N986B using Tapatalk
No doubt it will be a fault in the pump itself or the Adblue injector is blocked with crystallised Adblue. If its the latter, and the injector is easy to access, its a quick fix.
Saw someone the other day mention a product that you put in the fuel tank that stops/reduces the Adblue crystallising. It was a Wynns additive.
https://amzn.asia/d/54Orw8K
