2010 VW Crafter Shiftmatic fault
Hi,
I have an issue with my 2010 Crafter motorhome.
I have the engine light and the letter F up on my dash.
The Crafter wont select gears and won’t start.
I found the hydraulic pump was faulty and I have replaced it with a new one.
Also replaced the relay and checked the fuses.
Also replaced the hydraulic oil and the gearbox oil.
Still won’t clear the engine management light and F.
I have read the computer there is no fault code relating to this issue.
Any suggestions on how to clear this fault.
