Results 1 to 5 of 5
Thread: Windows going down by themselves...
    Sep 2012
    Question Windows going down by themselves...
    Hello all, twice now I've had all 4 windows go down half way when simply walking away from the car
    when I park it in the garage (unlocked). And I wasn't accediantly pushing the key fob.
    Anyone in any VW/AUDI had this?
    It happens after 10 seconds or so, not good.
    May 2007
    Quote Originally Posted by Andypoo View Post
    Not sure about that one...
    Keep us up to date!
    Mar 2013
    Brisbane QLD
    you might have a contact fault in the key barrel or the key barrel slightly sticking...Behind the cover on the drivers door handle you still have the key lock barrel in case the remote stops working to gain access...the lock only has to be very slightly turned off 90o to activate the windows...remove the cap and work the lock a few times and then try again....VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Sep 2012
    Quote Originally Posted by vdubmotorworx View Post
    There is no cover as such but I lubed the key hole (which I never use) and will monitor it.
    Many thanks.
    Canberra
    Did not read previous messages
    Last edited by ziggyboy; 16-07-2013 at 03:21 PM. Reason: Did not read previous messages
