Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: VW cost cutting at a whole new (lower) level!
    Sep 2011
    So I've had my MY12 Jetta 147TSI just after a month now.. Despite the obvious cost cutting measure in this new model, I figured that the benefits/strengths does outweigh the bad bits! However, as I was putting in some new bulbs (swapping them to Phillips Crystal Vision for the fogs, LED for the DRL etc), I discovered that passenger's front fog bulb was on the verge of getting blown! It had turned yellow'ish/grey'ish (sorta like a burnt colour). I don't switch the front fogs on at all but it lights up when I turn (static cornering light). I kinda shrugged that off, since I was changing them anyway.
    THEN.. as I was driving home from Mount Dande just now (with front and back fogs switched on), I somehow discovered, through reflection, that one of my rear fog light is already blown!! I don't think i've switched the rear fogs on more than 5 times!
    Wastegate rattle, bulbs... all within the first month... what's next??
    MY12 147TSI Jetta DSG | CW | Sports Pack | Sunroof | Driver Electric Seat | RCD510 | Formula 1 Tint | MFSW Paddle Shifters
    Jan 2007
    South Australia
    I would think that the globe is faulty and its not VWs fault might have been a bad batch.
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Buy the Octavia next time?
    Nov 2009
    SEQLD
    Does the new Jetta have 2 rear fogs now? MK5 version only has one.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
    Quote Originally Posted by Brendan_A View Post
    this... are you sure there is two to start with...?
    Jul 2009
    Geelong, Victoria
    sometimes I think we let brand loyalty get in the way of recognising that all too often there are reports of multiple problems with new cars, bad service centres, inflate parts pricing and questionable build quality at times.
    Unfortunately I am not in the position to buy a new dub, but if I had half the problems some guys seem to have I'd go ape***** in the service centre when problems wernt corrected properly by an authorised dealer.
    OK rant over...
    however, bulbs are a consumable item and VW didnt make them... interested to see how the replacements last
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Nov 2009
    Quote Originally Posted by frozze View Post
    If the fog is blown, you should get a bulb out error in the MFD (certainly when you switch on the rear fog). Is this happening? The Golf, MkV Jetta etc only have one bulb.
    Dec 2008
    Northern Suburbs
    Quote Originally Posted by Stan View Post
    OK rant over...
    Don't forget you only hear the negative, many people have hardly any problems with vw's so have no reason to post it on the internet
    Jul 2009
    Geelong, Victoria
    True, Pedies
    Sep 2011
    Hhhmm.. really? I didn't know that!
    I'll double check on that one. Why does it only have 1 side?
    Hope I didn't jump the gun on this one!
