Results 1 to 10 of 11
Thread: Reverse Camera
    Sep 2011
    Reverse Camera
    Thinking of fitting a reversing camera on my Jetta.. OEM handle camera..
    Anyone done it before or flirted with the idea?
    Wondering if it'll integrate well with the OPS..
    Thoughts and opinions welcomed!
    MY12 147TSI Jetta DSG | CW | Sports Pack | Sunroof | Driver Electric Seat | RCD510 | Formula 1 Tint | MFSW Paddle Shifters
    Jul 2012
    Lota, Queensland
    Of course it's a personal thing, but having experienced both a reversing camera and sensors, I personally think the sensors are better at this point. The camera image is distorted and the resolution is quite low. The depth perception of the various shapes on the image is also a problem. Lighting can be an issue as well
    When they combine the images with sensors I think you get the best possible outcome.
    Sep 2011
    Is your camera stock from factory or after market install?
    I have LEDs installed on my license plate and it's significantly brighter than the stock light bulbs, which I think can possibly help with the lighting issue..
    Quote Originally Posted by Silvertfox View Post
    Canberra
    Hi frozze long time no see...
    I've got a reverse camera on my Jetta. The boot handle is identical to those used in the Passat, so I ordered a Passat OEM camera from eBay with the harness, had it attached to my RCD510. Your radio then needs to be coded.
    I think the grainy camera resolution Silverfox is talking about is specific to the Golf camera. The Passat camera I'm using is crystal clear. I can take a photo or video for you in the next day or so. Again, we don't use the Golf (auto flipping badge) cameras, we use the Passat ones.
    Sep 2011
    Hey Ziggy! Was hoping you'd chime in.. When did you get yours done?
    Does it work well with the OPS? Did you install it yourself?
    I'm thinking of picking one up from one of the forum sponsor:
    http://www.vwwatercooled.org.au/foru...age-74298.html
    He recommended the VW Handle Camera and I'm guessing that's the one you got yeah?
    Quote Originally Posted by ziggyboy View Post
    Canberra
    I didn't do it myself. There are detailed instructions on how to do it yourself in the VWVortex Jetta VI forums and it seems straightforward... until the part where there's some coding needed. Having the mechanics do everything allows them to do end to end testing.. cuz if it doesn't work you don't know if it's your wiring or the coding. They spent a bit of time on my car as they haven't done Jetta+RCD510+Passat camera before... they've only done Golf+RNS510+Badge camera. The coding was apparently different too as it is the radio you need to code, not the ECU and they have never coded an RCD510 for a Passat camera before. In the end after much hair pulling they finally got it working. Turned out to be a problem with their coding.....
    But yes, it is the "handle camera" that I bought on eBay. Looks identical to mine, but was a lot cheper on eBay. AFAIK it was around $200-$250 delivered but the seller ran out of stock after a few weeks and haven't seen him sell cameras since. Don't have OPS on mine (got the Poverty Pack ) so can't say how well it works with it, but I can't see why not. They're all OEM. It'll probably just be like how it would work in a Passat. Oh and btw, you won't get those moving guidelines in the camera on higher end VW's.
    Canberra
    Frozze, one last but VERY IMPORTANT detail is... can you post a photo of your RCD510? Not all RCD510's got the video input at the back. The Bosch one does.
    See my old post here: VWVortex.com - Vw Jetta Backup Camera
    VW has contracted various electronic makers to build them RCD510's. They've got subtle differences and only half of them have got the video input at the back. Last thing you'd want is spend $$$ and find out your radio doesn't have the input!
    Sep 2011
    Yea I saw the guide but unfortunately, I'm not technically minded at all!
    Who did you get to fix it up? Not VW dealers, I'm assuming?
    I had a REALLY quick look on eBay but haven't found anything cheaper than the JKU. Turns out shipping is $50, so total for the camera is $500! Install is another $300-350!
    Sep 2011
    Oh thanks for the heads up.. Looks like mine is the Bosch model.. It's got the Media, Phone and Setup buttons on the right.
    I'm assuming you have the Bosch one as well?
    Canberra
    Yes I've got a Bosch model too. Make sure all 6 buttons are identical to that photo including the FM/AM/(diamond icon) on the left.
    I had it done in Redfern (Sydney). Forgot the name of the place but they specialise in VAG cars. I think it was around $300 too. I personally wouldn't suggest them though. The boss was pretty reassuring they've done it before, only to be told by the auto-electrician that he's done it only for a Golf and a different radio and he wasn't 100% sure what the coding was for the RCD510.
    I personally find them more useful than sensors. I drive my sister's car (not a VW) with sensors and find that having a camera actually shows you what's back there.
