Results 11 to 20 of 21
Thread: OEM LED tail lights
    Jun 2012
    Quote Originally Posted by Rawcpoppa View Post
    Thanks for the info. I have tried this 53 before but this was the result:
    "53/50
    PARK LIGHTS GOOD
    REARS DO NOT WORK AT ALL"
    I have yet to continue on from the value AA I am using. I think alot of the results have to do with how the lights are wired depending on who made the wire harnesses. 53 seems to work for many american Jettas but I don't think they have rear fogs in many instances although I might be wrong. Here are some of my quick notes for values that gave a pseudo positive response when I tried them in byte 18:
    "Original long coding 08000A3F882DE1C0C0080080040081E447200088508089605C 8020000040
    5d - check rear side light error
    drl stay on
    park lights dim
    no rear fogs
    5F
    DRL STAY ON
    PARK LIGHT DIM
    REAR FOG WORKS
    53/50
    PARK LIGHTS GOOD
    90
    PARK LIGHTS DIM
    OUTER TAILS LIGHT UP
    04
    REVERSE LIGHT ON IN PARK
    PARK LIGHTS ON WHEN SWITCH OFF
    DRLS NOT WORKING
    59
    DRL STAY ON
    DIM PARKERS
    A7
    NO ERRORS
    REAR FOG DIDN'T WORK. NAR MAYBE.
    AA WORKS.
    NO ERRORS. PARK LIGHTS USE OUTER BRAKE Lights TOO."
    Maybe just try my long code:
    00000A3A902D00C040080080000000E401005388508089605C 8000000040
    Trinidad and Tobago
    I've never used full long coding before. I'll have a look thru my code and yours and see what the differences are before I start changing things up. What model and year Jetta do you own again? Also where did you get your lights and wire harness from?
    Jun 2012
    I have a 2012 118tsi manual. I got the tail light from VW dealer in Adelaide, they have a great parts department at Solitaire !! So the tail lights are Genuine VW.. But i got the adapter cables for the connectors from car systems.
    May 2007
    And the perfect items to accompany OEM LED Tail Lights; OEM LED number plate lights...Part No. 3AF943021A.
    Also check this link; FS: VW OEM Genuine LED Number Plate Lights Part No. 3AF943021A
    Trinidad and Tobago
    Quote Originally Posted by ope126 View Post
    Do you have this installed in your Jetta? If yes do you get any errors? If no errors did you use adaptors with built in resistors or did you code it out?
    May 2007
    Yes I have these on my car. Just tweaked VCDS and no codes are thrown!
    These are still for sale if anyone is interested...
    Trinidad and Tobago
    What changes did you make in vcds? Can you pm me cost to ship to Trinidad and Tobago?
    Sent from my iPhone using Tapatalk - now Free
    May 2007
    Rawcpoppa, sorry mate for not getting back to you.
    The LED's are long gone, sorry...
    Trinidad and Tobago
    No worries. It's probably a sign to say I spend too much money on car mods anyway!
    May 2007
    Rawcpoppa - PM Sent.
    Check this out - FS: VW OEM Genuine LED Number Plate Lights Part No. 3AF943021A
