The DSG is a "great" gearbox, and is the way things will go. The problem is in the implementation of the technology.
The gear changes are flat so you don't let the turbo spool down and then have to spool up again. It is a direct drive so there is no loss through a torque converter.
VW should let customers know about it, but they are afraid that too many would be scared off.
The issue with the recall is that VW tried to ignore it and hoped it would go away. The issues outlined would have been known through accelerated testing, but incorrect judgements were made as to the likelihood of it happening in service.
The control of the gear shifting and clutch engagement is via software, so this should be able to be programmed to minimise such effects.
Dual clutch gearboxes are not unique to VW. They are used by many manufacturers, including the Japanese ones. But then the Japanes have their fair share of issues. There is the faulty pyros on the passenger air bag that involved quite a large number of vehicles. There is the Mitsubishi where the adaptive cruise control can think tunnel walls are vehicles and apply the brakes. There is Mercedes where the passenger air bag may not deploy properly because of an issue with the dashboard moulding.
So, don't think that buying a Japanese or Korean or Chinese or any other make is going to give you some apparent protection against faults. They ALL suffer from them.
On something a little different, I was watching a UK show and was surprised to see a Honda, Kia, Nissan and Jaguar, all with the indicator on the left hand side of the steering column. These same cars here have them on the right. I wonder how long it will be before all have the indicator on the left.
