Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Just picked up a used 2013 118 TSI Manual Jetta
    Erskineville, NSW
    Quote Originally Posted by jdw View Post
    Brad, I had the cracked piston issue and it was thankfully repaired under warranty. I believe once repaired they are ok as they use better parts.....thoughts ?. ( always use 9
    I'm told the new pistons are better but the root cause is lean fuel/air ratio. if the root cause isn't fixed then I'd think you are just extending the time between failures. Good excuse to get a remap that fixes the A/F ratios I guess.
    Oct 2017
    Wodonga, Vic
    Quote Originally Posted by gbarker View Post
    My Jetta is an April 2014 model and has 180,000 ks on the clock with no issues. Done servicing as per the handbook with the exception of engine oil and filter change every 7,500ks. Used RON95 80% of the time and 98 the rest. Do I need to replace the timing belt at some stage. I thought they were good for the "life of the engine" What does that mean?
    belt or chain? chain should last the life of the engine, if it has a belt it would have shredded by 180,000km
    Jan 2015
    Hornsby, NSW
    If servicing according to handbook, then likely it's already been done?
    Nathan
    Mine - 2013 MY13 VW Jetta 147TSI | Now with 3Bar ECU and DSG Tunes
    Hers - 2016 MY17 Skoda Fabia Wagon Premium Sports
