Results 1 to 5 of 5
Thread: jetta cruise control
    Jun 2009
    acacia ridge qld
    Hi guys have recently purchased 2007 jetts fsi with 28000 klm .i have a problem with the cruise control once switched on when i go to set the speed the thing stops working and the warning light on the dash goes out .making the cruise control inoperative .any body have any idea what the problem is or how much it will cost to fix .
    Nov 2005
    Sydney NSW
    wrong forum category - you are a Mk5
    anywho... sounds like a sensor is not working. the cruise cintrol monitors brake clutch and in dsg gear changes via selector or paddles.
    if one of thes is not working then it will cancel the cruise. do check the clutch and brake switches there should be 2 on the brake - one for lights and the other for cruise.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
    Jun 2009
    acacia ridge qld
    thanks for that will check them out
    Quote Originally Posted by 71dub View Post
    Very easy to check out the switching of the cruise with VCDS. I have it but there may be someone closer to you that can help.
    Gavin, Airport and North
    Aug 2007
    Common for stalk switches to fail mate, that will be logging a code in the engine ECU if thats the case, be a good bet its the stalk
    Jmac
    Alba European
