Results 1 to 5 of 5
Thread: Help needed re keys
    Apr 2008
    Bundoora Victoria
    Help needed re keys
    Hi all
    Hope I put this in the right spot. I picked up a 2006 1K TDI today, and, typical dealer, only got one key. It does have the remote unlocking.
    Is it possible to get a key with just the transponder and not worry about the remote?
    It's only for the spare set so I'm not too concerned about the remote as well. Also where would be the best place to get it? I'm in the northern suburbs of Melbourne.
    cheers...doc
    Mar 2013
    Brisbane QLD
    yes you can order a blade only or a key without remote.. dealer will get you one cut from singapore then it will need coding through the dealer online network....
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Apr 2008
    Bundoora Victoria
    Thanks vdub. I'll get onto it.
    cheers
    Apr 2008
    Bundoora Victoria
    Problem solved. Rang the previous owner as I had his details on the service receipts. He has another key and I'm picking it up tomorrow. Thanks for the suggestion vdub.
    cheers.
    Mar 2013
    Brisbane QLD
    lucky you!
