Results 1 to 10 of 13
Thread: Engine break in 1.4 tsi 118 kw
    Trinidad and Tobago
    I finally accepted delivery of my Jetta today and after looking thru the vehicle manual there is zero mention of a break in procedure. How does one break in a new car engine and tranny? Does the lack of info from VW mean this car can be driven like normal pretty much straight from the factory?
    Jan 2009
    Quote Originally Posted by Rawcpoppa View Post
    Yes, pretty much.
    Just avoid very high revs when cold, like you would in any car really.
    Also, gentle driving is the most efficient way to warm up modern cars.
    And do be careful since your brake pads and tyres will be brand new. You won't achieve maximum friction and grip until they also are run-in.
    Apr 2010
    Dec 2007
    GLENHUNTLEY,VICTORIA
    Enjoy the new Jetta,it finally arrived...
    Trinidad and Tobago
    Thanks. Liking it so far
    Oct 2010
    Melbourne, VIC
    I don't know the exact differences between the 118kW version and the 125kW version used in the Polo 6R GTi but the Polos have been reporting some big issues with poor ring sealing and excessive oil usage. The ones with the least problems seem to be the ones have have been hammered within the 1st 100km.
    see http://www.vwwatercooled.org.au/foru...ead-57967.html
    Resident grumpy old fart
    Jan 2009
    Quote Originally Posted by kaanage View Post
    One is badly made, the other one isn't.
    Those who didn't run it in hard suffered issues, but those who did also suffered issues. It's also been reported worldwide, so that would suggest to me a fundamental problem with the engine (which is probably the case) whose affect is far greater than whatever run-in procedure the owner chose to perform.
    Canberra
    Finally! Congrats on the new car. Just drive it normally and you'll be alright.
    11,000 kms on and my engine still does not eat oil
    Trinidad and Tobago
    Thanks again.
    By the way how does one quantify how much oil the engine is using? Dipstick just gives heads up on needing to add. *scratches head*
    Also, keyless entry feature should mean once I have the remote within a certain area of the vehicle I should be able to open doors without actually pressing the remote yes?
    Jan 2009
    The area between the MIN and MAX mark represents about 0.5 litres.
    VW says oil consumption may be as high as 0.5 litres/1000 km depending on how the car is driven.
    VW also says it is normal for new engines to consume oil at a higher rate than normal, but it should stabilise over time. If it consumes more than 0.5 litres/1000 km after 5000 km, see your dealer.
