From memory it's the supercharger winding down in conjunction with the vacuum water pump letting water into the turbo to cool it down after a drive instead of a turbo timer.. Correct me if i'm wrong!
2015 118TSI Jetta, 5,000kms on the clock...
A few minutes after parking in the shed (warm motor, just done over 30Ks) there is an intermittent sound (about every 30 seconds) that sounds for all the world like a small drill bit being sharpened. Lasts for a couple of seconds each time.
Any clues what it might be?
I SellNissansSkodas.
IT'S HEREEEEE 18' Skoda Octavia 110tsi Manual Hatch | Race Blue | Tech Pack | Luxury Pack | Panoramic Roof | Turini Alloys | Various VCDS Tweaks | RS Spoiler | Mars Bar Holder
R.I.P; 13' VW Polo 77tsi Comfortline Manual | Candy White | Sport Pack | Pioneer AVH X3800DAB + Clarion Bass Pack
Is it a hissing sound? Typically cooling down sound comes across like metallic sounds. I used to get metallic creaking sounds when my Jetta was new (less than 10,000 km). I believe it came from metal shrinkage as it cooled.
I now get a hissing sound from the mechatronic unit located to the front right side of the car when one is facing it. This is separate from the fans running for at least 15 seconds after shutting the engine off and these produce a sound of their own as well.
Probably normal but just tale it to dealer to check
2015 1.4 118 TSI Manual Jetta - APR CAI - GFB Diverter Valve - WORK SEEKER SX 18X8.5+35 - Muffler Delete - BC Coilovers - RCD 510
Don't think it would be the supercharger, that's driven by the motor so would stop turning when the motor stops.
Definitely a metallic sound - imagine the 'tring' sound a small drill bit as it touches a grinding wheel to be sharpened.
Thanks, blokes, I'll give the service department a ring...
