Results 1 to 5 of 5
Thread: Bluetooth module location on MY15
    Jun 2015
    Liverpool, NSW
    Hey all,
    I recently swapped out my RCD310 with a RCD330 but I need to remove/disconnect the stock Bluetooth module in my Jetta as the RCD330 has its own and it causing an issue with the phone button on my steering wheel.
    anyone know where the Bluetooth module is on 2015 Jetta... i've looked online and they say its under the seat but its not there on mine.
    thanks.
    Current 2023 T-Roc R-Line 140TSI | Past 2015 Jetta Trendline 118TSI
    Could be behind the head unit if it was retrofitted, or you might have one of the combined BT/MDI modules (5N0 035 729 A) that will either be the centre console, or glovebox.
    Jun 2015
    Liverpool, NSW
    thanks, I'll check there.... but i think you're right about the glovebox because i have a usb port inside there... now I'll have to figure out how to remove the glovebox.
    The MDI comes out forwards using radio removal keys you will see little slots in the bottom corners.
    Jun 2015
    Liverpool, NSW
    thanks, found it was on top of the glovebox part# 5N0035729D
