Results 1 to 10 of 14
Thread: APR Stage 1 - Jetta 147 TSi MK VI
    Jan 2013
    Brisbane, Queensland
    Decided to take the plunge and get a ECU upgrade. I have read up so much on this and what was common was as follows.
    Pro's
    - Upgrade is best bang for the buck you can get
    - Very little in the way of intruding into the car itself (ECU remap is my understanding)
    - Good support
    Con's
    - Warranty
    - Possible premature wear and tear on some parts
    - Torque for the 6 speed DSG
    - My son has a P so if he drives the car need to map back to stock for him
    - Insurance claim's
    Based on all of this I decided it was worthwhile for me to do the upgrade as I really enjoy the car and driving so a bit more oomph didnt seem like a bad thing. Let me address all of the Con's first.
    - Warranty. This is most people's biggest issue and I believe the one that needs to be looked into and accepted first before doing the upgrade. Sure they may never find out but lets be honest, for most enthusiasts even if they dont check the ECU a simple web search with your name will probably bring up a thread like this with all your upgrades. I am happy with this risk and if I have a warranty claim and they say it is due to the APR I am happy to to get them to prove it and would suggest with all of the negative publicity they have right now this is no issue. I also add that the reason I bought the car is because for engine I think they are well proven reliable cars regardless of the fact that some issues will always occur.
    - Premature wear and tear. Yep it's an issue, tires probably and I would say maybe brakes but happy to pay to play
    - Torque for 6 speed. The number of 350nm and so on being bandied about have no substantiation so I am just going to ignore this one as it has never been an issue for anyone.
    - My son's P's. I can reset to stock on the APR if I want and it is probably a good reason for him to drive his own car rather than mine
    - Insurance claim. I phoned up my insurer and told them I was getting an ecu remap and upgrade and they said as long as no new parts all good and nothing to tell them about.
    Thats what I have and how I made my decision to go for it. Will add more to this thread for those interested in terms of why I went APR, fuel economy stock vs tuned, performance and drivability etc.
    Neil
    Jetta 147 TSi APR Stage 1
    Jun 2009
    Glad you are enjoying it.
    Hope we can get you out to some of our events Neil.
    Sep 2012
    Neiliss - Was this not an anti-tune ECU, I went for a VIEZU check today at my local dealer but it's anti tune and needs to be taken out.
    Thinking of now going to APR. (I have the 1.4)
    Jan 2013
    Sounds like a plan I will check them out.
    Jan 2013
    Not 100% certain, basically from what I understand (and they did try and explain but I am a bit of a noob still at this) was that they could not flash it via OBD but it did have a relevant program. That meant they had to take the ECU out (they checked for security screws first which were not present) and form what I could see flashed it elsewhere in the workshop (I presume directly) and the put it back. All of this was pretty painless and took about an hour. I think that if they didnt have a flash for mine that apparently they would then have to take a copy of the ECU and send it to APR who would in turn send them a new flash for it maybe a week later, that was worst case but I didnt have to do that.
    Hope that kind of explains it from a laymans pov.
    Cheerd
    May 2007
    Well done mate - I trust you will enjoy the ride!!!
    Keep an eye on economy also, you might find it improves as well...
    Jan 2013
    Quote Originally Posted by ope126 View Post
    Yes I have just posted in the ECU Tweaks thread and already seeing it at least not look worse and possible seem better, but I think the best part is that when you are idling along there is still accessible power to go when you have to without having to kick down and I would expect blow fuel consumption away in the process which will lead to better overall consumption and a better driving experience.
    Now all I want is AWD on the Jetta
    Dec 2012
    Sutherland Shire, Sydney
    The Stage one torque is inside the 6 speed DSG capability - no problem there
    You will find that the top end power is down from stock - revs out slower over 5000rpm
    I proved this with back to back 0-100kmph runs
    I then upgraded to stage 2 and that was awesome
    I've dropped my oil change intervals from 15,000km to 10,000km to provide the engine a little better protection from wear
    I'm also going to change the DSG oil at 40,000km rather than 60,000km
    I'm absolutely certain this cheap initiative works because 3 weeks ago I bought a Nissan 350Z to use as club race car
    It has 248,000km on the clock and is still tight and performs better than 350Z's with 130,000km on the clock
    The car had one own from new, he changed the oil at 5,000km himself and also got the factory 10,000km services
    The high km have killed the economic value of the car but not it's performance
    Another thing you can do for the Jetta is get the supaloy front control arms
    These give more castor which provides additional straight line stability
    You can also adjust these to get -1.45 negative camber which improves cornering
    These also knock out axel tramp from hard starts
    It's a really great option to improve handling
    Jan 2013
    Quote Originally Posted by Martin View Post
    Hey Martin, thanks for the info. I have noticed the power shift difference already and actually find driving in D much more fun and no point moving to S for higher rev anymore. The in gear times seem very quick and even a bit manic with the DSC coming on in 2nd and even 3rd which is a bit crazy.
    As for other upgrades, I will run this one in and then see where we go. I love the car it suits me and has everything specced that I could so would love to keep it for a while and just add mods but probably wait for 6-12 months for the next set.
    Ciao
    N
    Dec 2012
    Quote Originally Posted by neiliss View Post
    Indeed - the stage 1 torque boost and the DSG shifting work awesome
