Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: Air intake question
  1. #41
    Trinidad and Tobago
    Take out the spring. The spring is not needed for it to work just like the stock DV. The spring provides the + aspect but if you encounter CEL's they recommend you just remove it.
  2. #42
    Jan 2016
    Melbourne, Victoria
    Yeah seems the way to go for now.
    Dont have vagcom and I dont fancy riding around with CEL lit up.
    I believe the original dv+ had a weaker spring and that made it trigger.
    2014 Jetta 118TSi manual.
    DV+, RNS-510
  3. #43
    Trinidad and Tobago
    The original DV works like the DV+ would without the spring. The trigger for cel is how the DV+ controls the boost with the extra spring installed. It doesn't let off all the boost in an attempt to give better throttle response. Some guys just clear the cel and it never comes on again. Maybe you can find someone with vagcom and try that first before removing the extra spring?
  4. #44
    Dec 2006
    Kilsyth, VIC
    I've not had any CEL or issues with the DV+ in mine.
  5. #45
    Jan 2016
    Melbourne, Victoria
    Quote Originally Posted by The_Hawk View Post
    Are you running the big spring that doesnt vent all the boost? Or just running it as a oem dv?
    DV+, RNS-510
  6. #46
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by pocketpunch View Post
    DV+, RNS-510
    Form memory there was only one spring in the box, which is the one I'm using.
