Results 1 to 10 of 10
Thread: ABS Sensor - Electrical error in circuit
    Jan 2025
    Suva, Fiji
    ABS, ESP, Steering Angle lights came on after both front tyres got changed. After scanning with OBDeleven it’s fault code 00285 saying electrical error in circuit. Replaced the sensor but the lights remain. Tested the sensor by jumping it to the other side, and the sensor reads fine on live data. It’s perhaps some issue in the wiring. As per the dealership, they’ve checked the sensor and the wiring, and supposedly it’s the control unit that is faulty, but they have no way of checking it for sure. Part is on order basis and ridiculously expensive. I don’t want to spend $4000 just to find out that was not the problem. I’ve checked the wiring myself, and I’ve tried to compare data with the left side. So the voltage reading to the sensor connector on the left side is 13.7V, and on the right side is 13.2V. As per auto electricians, this is normal. There is continuity from the sensor connector to the ABS control unit connector (J104). Resistance within the wire is the same on both left and right sides. Could it be that the control unit is faulty, but only for one wheel? Full scan below. Any help would be greatly appreciated.
    OBDeleven vehicle history log
    Date: 2025-01-16 10:59:09
    VIN: WVWZZZ16ZGM002531
    Car: Volkswagen Jetta
    Year: 2016
    Body type: Saloon
    Engine: CFFB kW ( hp) l
    Mileage: 70770 km
    Full scan
    Control Units: 16
    Fault count: 6
    Control Units:
    15 Airbag
    System description: AirbagVW10
    Software number: 5C0959655F
    Software version: 0613
    Hardware number: 5C0959655F
    Hardware version: 014
    Faults:
    No trouble codes found
    17 Dashboard
    System description: KOMBI
    Software number: 5C6920875A
    Software version: 1008
    Hardware number: 5C6920875A
    Hardware version: H04
    Faults:
    19 Gateway
    System description: J533 Gateway
    Software number: 7N0907530AT
    Software version: 1663
    Hardware number: 7N0907530AK
    Hardware version: H57
    Faults:
    05 Keyless System
    System description: VWKESSYPQ35GP
    Software number: 5K0959434E
    Software version: 1202
    Hardware number: 5K0959434
    Hardware version: 092
    Faults:
    25 Immobilizer
    System description: IMMO
    Software number: 5K0953234
    Hardware number: 5K0953234
    Faults:
    16 Steering Column
    System description: LENKS.MODUL
    Software number: 1K5953521CR
    Software version: 0230
    Hardware number: 5K0953569BF
    Hardware version: 018
    Faults:
    10 Parking Assistance
    System description: PARKHILFE 8K
    Software number: 1K8919472B
    Software version: 0479
    Hardware number: 5Q0919294A
    Hardware version: H03
    Faults:
    42 Driver Door
    System description: TUER-SG FT
    Software number: 561959701A
    Software version: 0515
    Hardware number: 3C0959793C
    Hardware version: 002
    Faults:
    52 Passenger Door
    System description: TUER-SG BT
    Software number: 561959702A
    Hardware number: 3C0959792C
    Faults:
    2B Steering Column Lock
    System description: ELV-PQ35
    Software number: 5K0905861C
    Software version: 0240
    Hardware number: 5K0905861C
    Hardware version: H21
    Faults:
    5F Multimedia
    System description: MU-S-N-ER
    Software number: 5C0035680B
    Software version: 0253
    Hardware number: 5C0035680B
    Hardware version: H20
    Faults:
    01 Engine
    System description: R4 2,0L EDC
    Software number: 03L906018TE
    Software version: 0251
    Hardware number: 03L907309R
    Hardware version: H25
    Faults:
    03 Brakes
    System description: ESP MK60EC1
    Software number: 1K0907379CB
    Software version: 0174
    Hardware number: 1K0907379CB
    Hardware version: H46
    Faults:
    00285 - Right front ABS wheel speed sensor
    static
    priority - 1
    frequencyCounter - 1
    drivingCycle - 111
    km-Mileage - 70779 km
    01325 - Tire Pressure Monitoring Control Module
    static
    priority - 2
    drivingCycle - 111
    02214 - Tire pressure warning
    static
    priority - 2
    drivingCycle - 111
    02 Transmission
    System description: GSG DSG AG6 531
    Software number: 02E300062B
    Software version: 4014
    Hardware number: 02E927770AL
    Hardware version: F10
    Faults:
    P184700 - Read DTC memory of
    ABS CM
    static
    priority - 0
    drivingCycle - 1
    44 Steering Assistance
    System description: EPS_ZFLS Kl. 70
    Software number: 1K0909144R
    Software version: 3501
    Faults:
    01316 - Brake control module
    static
    priority - 3
    drivingCycle - 111
    08 Air Conditioning
    System description: Climatronic
    Software number: 1K8907044AC
    Software version: 0304
    Hardware number: 1K8907044AC
    Hardware version: H05
    Faults:
    B10AF04 - Air quality sensor
    Faulty
    static
    Priority - 3
    Malfunction frequency counter - 1
    Unlearning counter - 111
    date - 2108-12-08 09:19:11
    @Muza: Hi.
    Hmm........clearly the new speed sensor is OK if it works on the other side of the car. So, there is something odd happening with the front right-side installation that's problematic. I don't have a wiring diagram for a MY16 Jetta, but I understand that it' has a PQ35 platform - so the same as a Golf mk6.
    Have you checked the toothed ring inside the wheel housing and is the air gap between the speed sensor and the toothed ring free of detritus?
    I'm not sure if the speed sensor has 2 x wire (or 3 x wires). If 2 x wire, with the sensor installed- hook-up a multi-meter to the sensor and rotate the wheel. With the multi-meter set to a low DC voltage range, rotate the wheel - does the meter show a reading?
    Finally, the speed sensor circuit to J104 is very simple and it's repeated 4 x times. Before you throw $4,000 at this problem - grab a wiring diagram and swap the wires for the front right-side wheel sensor for the speed sensor wires to another wheel at the J104 connector. The best way to do this is to de-pin the wires from the connector - but you might need to cut/splice the wires somewhere near the J104 connector instead. Then make a fresh SCAN.
    If the fault follows the swapped wires, the problem is NOT in the module! If you have tested the sensor by de-pinning the wires on the connector and the fault remains on the front, right-side - it's fairly clear that the J104 module is faulty
    Mornington Peninsula, VIC
    @DV52 Makes some good point about the toothed ring, something may of been damaged when the wheels were put back on. in this case I think the ring is built into the wheel bearing, but the idea of swapping the sensor input to the other side is a good one.
    Here is the test procedure with a scope for the sensor and ring Test
    But even just running a long jumper wire across to the other side and turning the wheel by hand while looking at the live data in the scan tool should do the trick.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Jan 2025
    Suva, Fiji
    Thanks Don, that was very thorough. I have the wiring diagram for the car, although I do not know how to post it up on here.
    I’d asked a workshop to take apart the wheel bearing assembly, and we cleaned the magnetic ring. This was after the fault first appeared, but that didn’t clear it anyway. I don’t think there is anything wrong with the magnetic ring or the sensor itself, because it worked just fine when I used a jumper wire to plug it into the left side harness (no errors on the left side, and live data read accurately).
    I tried the multimeter test last week, so at the sensor, there is voltage fluctuation as the wheel is spun, but if I connect the sensor to the harness, and then do the voltage test at the J104 end while spinning the wheel, there is no reading. For the left side, voltage fluctuates in both settings.
    That was enough to conclude that there was a problem with the wiring, but my electrician was adamant that it was the module when I told him the test results. His argument was that the readings just fluctuated coincidently 🤷*♂️.
    Swapping wires at the J104 connector was going to be my final test, which I attempted earlier today. I wracked my brain trying to figure out how to get the pins out, but the pins just did not seem to budge. I did not want to splice wires before the connector, so I’ll wait a week or two for the special tool to arrive from China and I’ll have another attempt then.
    @Muza: OK - I'm happy to look at the ABS wiring diagram if you want. Post-up the diagram on a third party hosting site (I use imgur - but there are lots of others on the electric internet) - then include a link to the picture here.
    Pacific Paradise QLD
    To post an image go down to bottom of your reply and click on advanced and a further bit will appear click on manage attachments and follow the prpmpts
    Jan 2025
    Suva, Fiji
    @Don - Here you go. Let me know if I am missing out on any portion, and I will try to upload that.
    @Hillbilly - thanks for the tip. Hoping it works.
    ABS Sensor - Electrical error in circuit-screenshot-2025-01-22-8-50-20-pm-jpg
    @Muza: OK - it's an entirely unremarkable wring diagram!!! Pretty-much the same set-up as every other VW model that has 2 x wire speed sensors.
    So, as we discussed previously - depin pin #42 and pin #43 from the 47 x pin connector on the Brake module and swap for the speed-sensor pins on one of the other wheels. Then remake a fresh SCAN - does the front-right speed-sensor fault follow the swapped wheel position. If the fault remains on the front-right position, the module is Cactus (it's an Aussie idiom - Cactus f#cktus! )
    If it does turn out to be a bad module, there are a few options, the 1K0907379CB was superseded with the 1K0907375CC in 2017, so you can look for a new or used part, $4000 from the dealer is just crazy.
    Second option is to have the unit repaired, https://www.youtube.com/watch?v=8siFD0wHsYk this video shows a good rundown on that process.
    anyway, best of luck
    Jun 2020
    QLD
    You can get a Vw mechanic to order just the abs module. I just had mine done on our MY16 Jetta. Volkswagon’s quoted $3900 to replace and $4800 to replace the mechatronic unit on the gearbox.
    I went my independent VW mechanic and while he couldn’t do the mechatronic unit much cheaper, he fitted only the abs controller not the whole brake controller for $1600. Vw quote you for the whole unit not just the abs controller. The best price secondhand unit I could find was $1000, by the time it was fitted and coded to the vehicle it would have been close to the same price as new.
    Lloyd
