I bought this one recently and it works with VCDS-Lite. So functionality provided depends on whatever VCDS-Lite gives you.. I can check and clear codes, change some settings etc.
Take a look at this: Ross-Tech: VAG-COM: VW Passat B5 Info
USB OBD-II VAGCOM KKL Check Engine Cable f Audi VW +2X2 | eBay
Will be this at least show me CEL's etc?
2009 125TDI Passat
2002 B5.5 1.8T Passat
The Ross-Tech site is a bit confusing - it says that VCDS lite won't work with CAN-Bus vehicles. I thought that VAG uses CAN-Bus![]()
Ross-Tech: VCDS-Lite
Not doubting you, jpflorez - I just want to confirm it works with late model VAG cars.
It's all good I doubt myself a lot! It seems that 2003+ vehicles have CAN-BUS (Ross-Tech: VAG-COM: CAN-Bus Information) but mine's 2002 so it works on mine. I assumed BrettD also has a 2002 from his sig..
