Hi, new to forum mk7 R cabin sounderkater knot shaw of correct spelling, wanting to know about how to delete or reduce sound % I understand it can be adjusted from 100% to zero in 10% amounts whats the pros and cons! Would like to adjust to my likeing I myself think its a bit on the loud side, any recommendations or advice on a good setting % ! Regards G.T.
Todd: not sure what tool you are using, but the process is easy! As to the volume for the Sounaktor that should be used, this is very much a personal thing. Because the process is so simple, just try a number (the percentage number can be changed in single digit numbers) and if you don't like it, then try another value.
Anyhow, if you are using VCDS, try this:
or if you have OBD11, try this
