It won't void warranty. You aren't modifying, you are enabling switched off factory features. It's actually less invasive than if you paid the dealership to fit an OEM accessory
Keep in mind that dealers generally don't know what VCDS is & won't / can't use the VW scan tool to enable other features.
I doubt you'll get mirror dipping to work unless you have electric seats.
Comfort indicator # of clicks is avilable via the MFD on that model isn't it?
The best advice I can give is to take backups of your config, make one change at a time & make sure it works without any side effects before making another change.
Also, don't tell the dealer that you've made any changes. As far as your concerned it came from VW like that.
