Results 1 to 2 of 2
Thread: VCDS - Perth, WA
    Jun 2016
    Perth, WA
    VCDS - Perth, WA
    Hi All,
    Wondering is there anybody around Perth metro area with the capability of hooking up to a RCD510 in a 2011 Amarok, need to find Aux In option so I can enable it.
    Currently when I go to - Setup > Media 'Enable Aux Input' is no where to be found.
    Thanks
    Mindarie, Perth (WA)
    do you actually have the Media Device Interface (a separate component)?
    Media Device Interface (MDI)
    This convenient feature allows you to connect your USB media player, storage device or iPod® to the audio system. The MDI includes a USB cable to connect your media player to the audio system – an iPod cable, USB mini and Auxiliary cable are available as an accessory. The device may then be controlled by the in-dash system rather than its own interface, making operation safer and easier. Best of all, the MDI connection will charge your portable device up while it’s connected.
