View Poll Results: Which Tool to buy
Voters
11. You may not vote on this poll
  • VCDS HEX-V2
    4 36.36%
  • OBDEleven
    7 63.64%
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: VCDS or OBDEleven for Skoda / VAG's
  1. #21
    Aug 2020
    Hampton Victoria
    Eos my07
    not sure -I'm not familiar with MY07 Eos. Perhaps look on the OBD forum, or the Ross-Tech forum
    I Don. The eos my07 is the same as a golf mkv
  2. #22
    Quote Originally Posted by Zgarymclz View Post
    Gary: Again, I'm not familiar with a EOS, but here's a long code screen from a 3C0-937-049 module - which I understand is fitted to Golf mk V vehicles (Google "3C0937049 MKV")
    This screen shot comes from a VCDS device, but it doesn't matter - I've included it to confirm that the module enables user control of cold diagnosis
    If your EOS has the same module - Byte 19, Bit 0 is the software switch for cold diagnosis on the low-beam lamps. The PRO version of OBD11 should be able to turn-off this function (simply flip the status of the Bit).
    OBD11 calls this module "Central electrics" and it lives @ address hex09 on the CAN network
