Hi all
Just looking for someone with vcds or obdeleven around Brisbane who will rent or will help with some programming in my vw up.
I need to do a bcm swap for a cruise control retrofit.
PM, me I can help with VCDS. Just need to research what you need coded as I haven't done a BCM swap on the Up! before.
Mooloolaba isn't really brisbane
I want to just plug a bcm in and change 1 setting to see if what I was told works. Easy 5 min job for obdeleven or vcds that some one with at home would take a 6pack or a few dollars to do it. For 180 an hour I would just spend the extra few dollars and buy a obdeleven.
