![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
wai
G'day,
Came across an iPhone/iPad app called VCDS Mobile that allows scanning the system to check for error/fault codes.
The app is free, however the wireless transmitter/receiver that pligs into the OBD port has to be bought (much like the cable that plugs into a computer).
Anyone tried it?
Wai: I assume that you are referring to the apps that require a separate dongle based on the ELM327 programmable microprocessor (you can buy the dongles in either Bluetooth or WIFI connect models). They are about $10 to $20 to buy and I purchased aWIFI unit from Ebay about a year ago.
I have to say that it's really a toy in comparison to the VCDS cable but it does't pretend to be a Ross-tech equivalent. The apps allow you to display ODBII data like: engine rpm, speed manifold temperateur, coolant temp etc. Some even claim to be an actual diagnostic tool, but you need to be wary of such claims. I had a passenger door control module error on my car and the ELM wasn't able to detect it
Conclusion - it's a fun thing to try, doesn't cost much - but don't be surprised if you end-up giving it away after about a week - I did!!
