Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: VCDS label file for GT TDI engine, BMN 125kW/170PS
  1. #21
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by benough View Post
    As soon as you change the value for the EGR in the adaptation it says "ERROR" and that security code didn't work.
    I knew it wouldn't be that easy but the values I was getting is %60 EGR at idle.
    Idle EGR sounds right, it decreases as the demand for O2 increases, but I can vouch for the fact the car runs way smoother and just fine without it!
  2. #22
    Jun 2011
    That's some very interesting information there, I've already put it to good use with the help of Gavin.
    On the EGR adaptation though, this thread would suggest that there is no way to do this through VCDS on a mk5.
    Just curious with that DPF sensor adaptation, after the 30605 login code is accepted, is that the end of the procedure? Does it just adapt while the car is driven around? I was a little confused as I thought acceptance of login code just meant I've logged in, it doesn't say anything about adaptation.
  3. #23
    Oct 2010
    Quote Originally Posted by DkN View Post
    Its not a login code its a Coding II code. You just need to enter it then turn the ignition off for 30 seconds.
    Golf GT Sport TDI
  4. #24
    Jun 2011
    Righto mate I just got confused because it said something about "login accepted" after the code is entered. Cheers
  5. #25
    Oct 2010
    If anyone tried to access the file in the last week sorry, the server was down.
    Golf GT Sport TDI
