No battery regulation. Code that out.
Also worth posting all your current issues with the Gateway swap in one thread. Easier for everyone to keep track of where you're at![]()
Hi Guys
I was hoping someone could give me some advice on the following errors?
The 'Central Convenience' is listed below but for some reason the 'Battery Regulator' error does not show, it only shows when I go to the actual module and look at the fault there. I did not copy this tonight, I will get this error tomorrow. However, the Battery Regulator error has only been occurring since I upgraded my CAN-GATEWAY tonight for my RCD510 upgrade.
others also have this issue: http://www.mk5golfgti.co.uk/forum/in...;topic=31684.0
Thanks!
Tuesday,30,July,2013,22:31:12:60875
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: xxxxxxxxxxxxxxxx Mileage: 71620km/44502miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 91C802087F2D8505485FC69010
Shop #: WSC 50620 812 60948
VCID: 7BDB2A1C3A08ABC0759
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 1K0 951 177
Component: Innenraumueberw.004 0101
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Clear the code, and re-scan the car. It should clear.
'01 Beetle 2.0
I have done that. It keeps coming back...
