Results 1 to 5 of 5
Thread: VCDS Errors - What do they mean?
    Oct 2010
    Perth, WA
    Hi Guys
    I was hoping someone could give me some advice on the following errors?
    The 'Central Convenience' is listed below but for some reason the 'Battery Regulator' error does not show, it only shows when I go to the actual module and look at the fault there. I did not copy this tonight, I will get this error tomorrow. However, the Battery Regulator error has only been occurring since I upgraded my CAN-GATEWAY tonight for my RCD510 upgrade.
    others also have this issue: http://www.mk5golfgti.co.uk/forum/in...;topic=31684.0
    Thanks!
    Tuesday,30,July,2013,22:31:12:60875
    VCDS Version: Release 11.11.6 (x64)
    Data version: 20121223
    Chassis Type: 7N0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
    VIN: xxxxxxxxxxxxxxxx Mileage: 71620km/44502miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 BL
    Component: 01 KSG 0301
    Coding: 91C802087F2D8505485FC69010
    Shop #: WSC 50620 812 60948
    VCID: 7BDB2A1C3A08ABC0759
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 B
    Component: Neigungssensor 004 0003
    Part No: 1K0 951 177
    Component: Innenraumueberw.004 0101
    1 Fault Found:
    01134 - Alarm Horn (H12)
    004 - No Signal/Communication
    Dec 2008
    Sydney/Canberra
    No battery regulation. Code that out.
    Also worth posting all your current issues with the Gateway swap in one thread. Easier for everyone to keep track of where you're at
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Oct 2010
    Perth, WA
    Quote Originally Posted by Umai Naa!! View Post
    Thanks - Sorry, saw this as a new issue so I opened a new thread. I will close the others.
    I have had a look and I have not selected "battery regulation" in the installation list.. its unticked..
    Dec 2008
    Sydney/Canberra
    Clear the code, and re-scan the car. It should clear.
    '01 Beetle 2.0
    Oct 2010
    Perth, WA
    I have done that. It keeps coming back...
