First thing to try is clear al DTCs and rescan.
When you pull parts out and replace them you will often generate fault codes due to detected open circuits.
Hi guys - firstly my tiggy is a 2010 (MY11) 147 - has the standard RNS510 so grabbed a new RNS510 with navigation...version H - HW 61 with software revision 3970.
I also purchased this:
VW Bluetooth KIT 7P6035730F - Retrofit -
so today I removed the old RNS510 and wired up the bluetooth kit (which was relatively easy) and hooked up the Ross-Tech HEX-USB+CAN Interface so I can carry out some coding. First thing was to carry out an auto scan and save it just in case I did something stupid then I looked for 19 (CAN Gateway) and enabled navigation and Telephone, after this they both appeared in the MFD - that was pretty simple I thought. For my next trick I went into Address 37 and check for error codes - see below:
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 H HW: 1T0 035 680 H
Component: RNS-MID H61 3970
Revision: AB001001 Serial number: xxxxxxxxxxxx
Coding: 04010402040000800005
Shop #: WSC 01357 011 00200
ASAM Dataset: ------------------------- ------
VCID: 336F2AB2922E49B
3 Faults Found:
00859 - Line-Output; Front Right
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
00823 - Line-Output; Front Left
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
01523 - Microphone for Telephone (R3![]()
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28881 km
Time Indication: 0
Date: 2019.14.06
Time: 18:01:31
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Revision: AB001001 Serial number: xxxxxxxxxxxxxxxxx
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28880 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 28881 km
Time Indication: 0
Date: 2019.14.06
Time: 18:01:31
It looked like to me that this was faulting as the bluetooth unit wasn't coded as it threw back the following:
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H12 2730
Revision: 1B001001 Serial number: xxxxxxxxxxxxxx
Coding: 0A00000000010100
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA_VW36.rod
VCID: 356B14AA945A57B
2 Faults Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 28873 km
Date: 2019.14.06
Time: 15:43:00
13636352 - Control Module Not Coded
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 19
Mileage: 28873 km
Date: 2019.14.06
Time: 15:43:01
Dumb question but I have searched everywhere and my coding appears to be different than others I have viewed in this and other forums so what else do I need to enable/disable as I cannot see anything else that should be - any tips, pointers etc are most welcome TIA![]()
thanks for the reply...just cleared all the faults codes and they came back + also rebooted the RNS510...when I installed the piggy back cable for the bluetooth the mic wire was not connected when it was delivered + there was 2 places to plug the mic into (there are 3 connectors all together) are you able to confirm which single plug the mic should connect to? - thanks
Do the front speakers work?
The Bluetooth mic pass through should go to the mic in on the rns510
yep they all work, anyway, I removed the RNS510 so I could check the connections I did find the terminal on the mic a bit dodgy so fixed it up then I adjusted a couple of minor codes like "no sound system" (no amp under seat anyway) and "Display variant" (cosmetic only) then rebooted the unit and all is working as it should. The BT device I purchased from carsystems and all I did was to enable the telephone in the CAN gateway and that was it - interestingly if I clear all the fault codes then carry out a full rescan they do re-appear but everything works as it should...the BT in the MFD, all the steering wheel buttons (left and right), contacts (iPhone 4s) so my guess is that as the BT is aftermarket it still logs a fault but works so maybe the only way to clear this is to go to my friendly dealer (not) and hook it up to the mothership and get them to accept the faults - I have no idea?
The only issue that has popped up is the NAV (Ver H / 3970 / Ver 5 maps) for some reason when viewing the map you seem to go "off-track" and it is really slow to respond and to give your correct location, maybe a few seconds behind you in real time - I checked the antenna and all is good and have anywhere between 6-8/11 satellites at one time - I remember reading about his and was told it should fix itself over time so if anyone else has any pointers they would be most welcome![]()
the errors will reappear on the Bluetooth module because you havnt set a work shop code (WSC)
