![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
WOJ
that is correct, I would like to have the tail lights ON at the same time as my daytime running lights. You are right that I can achieve this by switching the light switch to low beam, however when the switch is in this position the dash lights turn on, and each time I would need to turn the switch to OFF or Auto position when I turn the ignition off, otherwise the low beam lights will remain on! Someone has told me this DRL option is called Scandynavian mode??? VW dealership does not know what I am talking about?
Scandinavian tails are usually done on cars with LED lights and can be done with an APP using an OBDEleven My TIg has it done and it puts your taillights on with the front DRL's but no other front light
