Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: VCDS assistance Sydney
    Jul 2014
    I was actually just playing around with the Central Electrics in my brothers 2010 GTI. Trying to activate fogs as drl as well as have them remain on all the time. Can’t be done.
    As for rear drl.. I’m not sure why you would want that, nevertheless didn’t come across it anywhere.
    Apr 2008
    That's odd, as the MK5 platform will do it.
    Maybe, as MK6 platform cars all had proper DRL's, they removed it?
    Apr 2008
    In a GTI, when you turn the car off, and the light switch is on low beam, the lights will turn off. My MK5 is a highline cluster and I have been doing this for 10 years.
    I have seen Scandanavian mode in VCDS before, and it leaves the low beams on, regardless of the headlight switch, so in essence, yes it will do what you want, but it's the same as leaving the low beams on the whole time.
    Feb 2018
    Ryde, NSW
    Hi Benough,
    when you you say low beam, do you mean just parking lights? If that is the case, in my car these stay on indefinitely, after the ignition is turned off, and the car is locked! For that very reason, I would like to activate the Scandinavian DRLs mode, if at all possible through the VAG COM cable?
    Apr 2008
    Low beams are the lights that you use at night to see where you're going.
    No parking lights are to be seen, not to see others
    Scandanavian DRL mode is having the low beams on regardless of the light switch position.
    Yep, I can do that for you in a lunchbreak if you like?
    Feb 2018
    Ryde, NSW
    That would be much appreciated, I live in Ryde and work at North Ryde, let me know when it suits you and I will try to fit in with you. Also if you prefer let me know how to get in contact with you?
    Jul 2009
    Hi benough, I have a Skoda Mk3 that I could use some help with coding. I want to install a reverse camera but first need to switch the reverse light pulse wave modulation byte from AC to DC to ensure a smooth current.
    I don't have vagcom/vcds nor the cable. Could you help out? Cost?
    Thanks in advance!
    Skoda Octavia Mk3
    (sold) Golf Mark 6 Comfortline 118
    (sold) Golf Mark5 Comfortline Manual 2.0 FSI
    Nov 2019
    Hi,
    I would like to do some VCD mods on my Audi. Is there anyone in Sydney that has a Ross-Tech plug that I could use to do this mods? Happy to pay for the use of it.
