Quote Originally Posted by gavs View Post
Got a few good ones here, especially for the GTI owners out there!
In VCDS Select Control Module, go to 03 ABS Brakes, then 10 Adaptation, go to Channel:
Channel 09 Brake Assist
There are 3 settings for this
0-center (stock setting)
1-small
2-hard
The stock setting is 0, change it to 2 and this makes the brake pedal more responsive to smaller inputs. Feels more positive in use, especially under enthusiastic motoring.
Channel 36 XDS
1-weak
2-strong
Change this from 0 to 2 and this one mod alone apparently makes the Polo into a different/better beast under hard driving.
Changed these settings last week and WOW what a difference with the XDS setting at strong. Definitely noticeably flatter over corners and the steering seems a tad heavier too. Should have been like this from the dealership!!
The brake assist set to hard didn't seem too much different except unless I press down half pedal then it seems to stop bit harder than normal.
