Page 1 of 8 123 ... LastLast
Results 1 to 10 of 78
Thread: VCDS For 6R Polo (primarily GTI)
    Jun 2008
    Ringwood, Victoria
    Needle Sweep:
    Found under instruments, known as "Staging". Controller unavailable on my specific GTI. Apparently only available on the GTI instument cluster...
    Door auto lock at 15kph: Have tried and activated relevant module, not happening
    Hatch auto lock at 15 KPH: See above
    Comfort indicater: flash count changed from 3 flashes to 4, found under the "comfort" measuring block
    Jun 2008
    Ringwood, Victoria
    just as a follow up, found that my car had the wrong software installed for all the comfort and convenience control module, possibly could explain why certain things didn't happen when activated....
    VIC
    Hi everyone - I'm new to VW Polo ownership - is turning door and hatch auto lock something my local dealer can do on my Polo GTI or do I have to take it to a tuner with the VCDS package?
    2010 Golf TSi & Polo GTI White MY12.5 - VIC
    Mindarie, Perth (WA)
    Quote Originally Posted by syd View Post
    Dealer can do it (should be at no charge)
    Jun 2008
    Ringwood, Victoria
    Got a few good ones here, especially for the GTI owners out there!
    In VCDS Select Control Module, go to 03 ABS Brakes, then 10 Adaptation, go to Channel:
    Channel 09 Brake Assist
    There are 3 settings for this
    0-center (stock setting)
    1-small
    2-hard
    The stock setting is 0, change it to 2 and this makes the brake pedal more responsive to smaller inputs. Feels more positive in use, especially under enthusiastic motoring.
    Channel 36 XDS
    1-weak
    2-strong
    Change this from 0 to 2 and this one mod alone apparently makes the Polo into a different/better beast under hard driving.
    Seems more planted around bends and that much better to push through the corner on exit. This mod comes with a five thumbs up...
    Apr 2011
    Sunshine Coast, QLD
    Nice work, gavs! Will you/ have you changed your software, given they installed the wrong stuff?
    Also, is it just me? Isn't making 0 the middle setting on those controls ridiculous? Logically, 0 should provide weakest settings, 1 centre and 2 hard. That was my assumption when I read your braking thread in the Polo 6r section. Thanks for referring me here.
    Dec 2008
    Sydney/Canberra
    As with all VW's programming logic, Zero is always the default setting.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2008
    Ringwood, Victoria
    Yes, I had the proper software installed at another dealership, they are the ones that picked it up when I found I had mental climatronic.
    hmmm...hooked the VCDS cable up today to the Polo.
    Scan reports no Gateway!!!!
    Can't access any of the modules (well I can, but comes back with the Windows based "BA-BOW" and a dialogue box that says No Gateway or similar)
    HELP
    Quote Originally Posted by FJ Steve View Post
    HELP
    *bump*...any thoughts?
