Originally Posted by
achilles6R
Hi there guys...does anyone know if the staging/needle sweep can be done on my 2010 polo 6R?
which VCDS version do i need?
thanks!
achilles6R: Here's how I activated the needle sweep function on my Polo 6R. I used a genuine Ross Tech cable HEX+CAN (USB version) and Beta SW (14.6.1), but I suspect that the current VCDS release SW (12.12.2) will work too. Please be aware that the latest RT software is not fully compatible with the 6R platform (it's mainly an issue with the long coding incorrectly displaying the status of the controller bits). Sebastian at Ross Tech says that he is aware of the problem and that it's still a work in progress. That said, the software is sufficiently compliant to be able to do (most) tweaks -including this one.
Needle Sweep on Polo 6R - VCDS Tweak
1. Select the installed controllers page from the main Ross Tech screen
2. Click 17-Instruments from the control module list
3. Click on Adaptation-10 tab
4. Click on the pull-down channel tab and select indicator_celebration (it's about 80% down the channel list)
5. Select Active in the "New Value" box and click Do It! tab
6. Click Add to Log and save a copy of the change report
7. Click Go Back tab and exit the VCDS software
That's it!
This is a whimsical tweak - it's fun to watch the needles dance when the ignition is turned-on (well.... perhaps fun for the first couple dozen times)!
