Finally invested in a Ross-tech cable tonight and have applied the Auto lock/unlock and XDS changes.![]()
Changed these settings last week and WOW what a difference with the XDS setting at strong. Definitely noticeably flatter over corners and the steering seems a tad heavier too. Should have been like this from the dealership!!
The brake assist set to hard didn't seem too much different except unless I press down half pedal then it seems to stop bit harder than normal.
Polo 6R GTI - Candy White | MY12.5 | 5 dr | Weitec Hicon GT | OZ Ultraleggera | SPOC - 1st Four
MY12.5 Candy White 5 door Polo GTI. Upgrades/Mods = RNS510 H LED, RVC camera, Auto Lights Dash Sound Actuator GTI button, Gavs Footrest(!)
WIP = Miltek Turboback Exhaust, Cold Air Intake, Red Stuff brake pads (Nov '13)
Hi there guys...does anyone know if the staging/needle sweep can be done on my 2010 polo 6R?
which VCDS version do i need?
thanks!
Evening, just got some time at work to try the "indicator celebration" on my 13.5 GTI and it does work, not sure if it has been covered earlier.
MR
MY 13.5 Candy White Polo GTi, with Xenons....
- Gloss Black roof, Weitec, Whiteline, APR and Harding Performance bits![]()
- Sound, Mosconi D2 100.4DSP, Mosconi D2 150.2, HAT L6SE Carbon
List of things to add, custom built subwoofer enclosure by Drivesound
have a future project in mind and was wondering who would be best to help out with the coding side of things. Not sure if this has been done to a polo yet so need the best person for the job.
Basically, i'm looking for a VCDS guru in melb or syd (prefer melb but willing to travel to sydney get this done). would love to chat more by pm, trying to keep this sneaky untill its compleated... though now buy posting this people will be curious.... still not telling...
thanks in advance,
Ben
Does anyone have the same problem as me where ABS > Adaptation > Channel 36 is "not accessible". I've tried VCDS 11 and 12 beta and have the HEX+CAN cable. Channel 36 is supposed to be the XDS channel but it must be a new controller. There is no documentation drop-down either. I'm keen to get and XDS or EDL settings for this car.
I think it's an MY11 thing because it has the 1-digit steering weight setting rather than the older 2-digit. I guess XDS may have changed too but nobody's documented the new settings![]()
08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
http://photobucket.com/gregsr32
I'm hoping someone can help me with two annoying "features" on my new GTI please:
1) I often like to drive with the climate control set to low without AC (i.e. just fresh air). When you turn off the ignition and later come back to the car the climate control defaults to "22C with AC". Is there any way to change the default to low with no AC?
2) Is there a way to change the default zoom level on the nav maps in the RNS510? It seems to default to "outer-space" distance so every time you get in the car you have to zoom back into 100m level. Don't want to wear out the dial
Many thanks.
Gone: Aug 2013 Build MY14 Polo GTI | Candy White | RNS510 | Panoramic Sunroof | Bi-Xenons | Rear Parking Sensors
Current: Late March 2015 Build Mk7 Golf GTI Performance Pack | Pure White
I have discovered these few channels in the ABS module.
Channel 21 SMALL/LARGE
Channel 35 ON/OFF
Channel 51 ENABLED/DISABLED
Channel 58 Center/EARLY/LATE
Channel 73 On/OFF
Any VAG VCDS experts know what these controls? I am trying to delay ASR activating which allows some slipping and if possible activating it only after 30km/h
