Page 1 of 3 123 LastLast
Results 1 to 10 of 78
Thread: VCDS For 6R Polo (primarily GTI)
    Jun 2008
    Ringwood, Victoria
    Needle Sweep:
    Found under instruments, known as "Staging". Controller unavailable on my specific GTI. Apparently only available on the GTI instument cluster...
    Door auto lock at 15kph: Have tried and activated relevant module, not happening
    Hatch auto lock at 15 KPH: See above
    Comfort indicater: flash count changed from 3 flashes to 4, found under the "comfort" measuring block
    Jun 2008
    Ringwood, Victoria
    just as a follow up, found that my car had the wrong software installed for all the comfort and convenience control module, possibly could explain why certain things didn't happen when activated....
    VIC
    Hi everyone - I'm new to VW Polo ownership - is turning door and hatch auto lock something my local dealer can do on my Polo GTI or do I have to take it to a tuner with the VCDS package?
    2010 Golf TSi & Polo GTI White MY12.5 - VIC
    Mindarie, Perth (WA)
    Quote Originally Posted by syd View Post
    Dealer can do it (should be at no charge)
    Jun 2008
    Ringwood, Victoria
    Got a few good ones here, especially for the GTI owners out there!
    In VCDS Select Control Module, go to 03 ABS Brakes, then 10 Adaptation, go to Channel:
    Channel 09 Brake Assist
    There are 3 settings for this
    0-center (stock setting)
    1-small
    2-hard
    The stock setting is 0, change it to 2 and this makes the brake pedal more responsive to smaller inputs. Feels more positive in use, especially under enthusiastic motoring.
    Channel 36 XDS
    1-weak
    2-strong
    Change this from 0 to 2 and this one mod alone apparently makes the Polo into a different/better beast under hard driving.
    Seems more planted around bends and that much better to push through the corner on exit. This mod comes with a five thumbs up...
    Apr 2011
    Sunshine Coast, QLD
    Nice work, gavs! Will you/ have you changed your software, given they installed the wrong stuff?
    Also, is it just me? Isn't making 0 the middle setting on those controls ridiculous? Logically, 0 should provide weakest settings, 1 centre and 2 hard. That was my assumption when I read your braking thread in the Polo 6r section. Thanks for referring me here.
    Sep 2012
    Doncaster
    Anyone available this coming Sunday - 30/09/2012?
    Hey guys,
    Anyone available with a controller to change these settings this weekend?
    I can provide alcohol =).
    PM please.
    Thanks!
    Quote Originally Posted by gavs View Post
    1-small
    2-hard
    Channel 36 XDS
    1-weak
    2-strong
    Jul 2011
    1-small
    2-hard
    Channel 36 XDS
    1-weak
    2-strong
    Changed these settings last week and WOW what a difference with the XDS setting at strong. Definitely noticeably flatter over corners and the steering seems a tad heavier too. Should have been like this from the dealership!!
    The brake assist set to hard didn't seem too much different except unless I press down half pedal then it seems to stop bit harder than normal.
    Polo 6R GTI - Candy White | MY12.5 | 5 dr | Weitec Hicon GT | OZ Ultraleggera | SPOC - 1st Four
    Jul 2012
    Melbourne, VIC Northern Suburbs
    I'd love to be able to disable Daytime Headlights (different to DRLs) on my car, but I've got halogens not xenons - can anyone help??
    Polo GTI MY13 (CTHE) | 5D | CW | Sunroof | DL Tint | VW Handy Adapter for iPhone 4/4S | DHL disabled
    VCDS tweaks: XDL - Strong | Brake Assist - Hard | Auto Lock Doors/Hatch - On | Two Stage Unlock - On | Audible Locking - On | Lane Change Function - 4 flashes
    Oct 2012
    Have a look in this thread:
    How to deactivate daytime running lights?
    Works perfectly.
