Results 1 to 10 of 13
Thread: VAG Diagnostics Cable and ROSS Tech
    Jul 2012
    Just wondering, if any one has used the above combination and what they think of it and if any issues were encountered.
    As my Laptop seems to be unable to communicate with the car POLO GTi and POLO TSi and GOLF Mk6 TDi when connected to the computer.
    Any advise would be great
    Quote Originally Posted by GTI14L View Post
    What OS are you using?
    Have you tested it like it says to when you first use it?
    Does it get recognised when you connect the lead? Drivers installed.
    The lead is most unlikely to be busted. I have had getting for half a dozen over the years and they have all worked fine.
    They should certainly work on all 3 vehicles listed. Even with the micro-CAN lead.
    Ross-Tech: VCDS Tour
    Ross-Tech: FAQ
    gavin
    Aug 2011
    He's talking about the shonky one that the site Vag-diagnostics sells. I believe it uses a very old, pirated version of VCDS. Mind you the cable is meant to still work as a CAN-HEX cable, meaning it should've worked for all three cars (Micro-CAN doesn't work on the Polo).
    I'm guessing the issue is with your VCDS install, does the test function in options -> test go through ok?
    And is the key turned to acc (the one before starting the engine)?
    May 2012
    Silly question, is the ignition on.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    Quote Originally Posted by readerr0r View Post
    The real thing always works, free back up.
    May 2012
    Dam beat me to it reader0r. I hit post and both our post came up at the same time
    MY12.5 Polo 6R GTI
    Sep 2012
    Joondalup, WA
    The answer to the problem is VW has just changed the communication system in the newer vehicles.
    we used to run VAS PC which talked to the control units using KWP (key word protocol)
    we have just had a massive overhaul in our diag equipment changing over to ODIS which uses KWP and the new system UDS
    unfortunately the VAG com equipment cannot communicate with these vehicles, however from my experiences the only control units running on UDS seem to be all on the Drive CAN
    hope that helps
    Steve Ariaans - Commercial Mechanic
    DVG Melville Volkswagen, 170 Leach Hwy, Melville WA 6156 Tel: 08 9330 0777
    Follow Us on Facebook
    Quote Originally Posted by vdubmech87 View Post
    hope that helps
    That hasn't affected my proper VCDS cable.
    Sep 2012
    Joondalup, WA
    That's interesting Gavin, i've had a lot of complaints from people i know in regards to the new generation UDS vehicles. however i think you may have hit the nail on the head with the use of the word "proper"
    Steve
    VCDS is constantly evolving, I have had an ebay cable in the past and if you are on MK4s and ME7 equipped cars, they work ok. Since signing up with Custom-Code it doesn't make sense to suffer all the problems you find with cheap cables. The coding helpers are worth every penny of teh cost a real cable as far as I am concerned.
