Page 46 of 47 FirstFirst ... 3644454647 LastLast
Results 451 to 460 of 463
Thread: VAG-COM scanning, who can help
  1. #451
    May 2022
    Canberra
    Anyone in Canberra/ACT with a tool to teach the 2017 passat about new battery? Thanks,
  2. #452
    Oct 2024
    Sydney VCDS help
    Gday all, need some vcds assistance please🙏 I have a mk6 gti steering wheel swapped into my 2013 passat alltrack. Need the paddle shifters activated. Happy to travel sydney wide
  3. #453
    Jan 2025
    Kingston
    Hi all. Wondering if there is anyone in the Canberra area that could scan a 2018 VW Polo due to me having to change the battery on the way down from QLD. I will travel anywhere that suits you and work from home, so am very flexible. I happen to be a wine collector if that helps...
    [Update] Issue resolved. Many thanks to the community for helping out.
  4. #454
    Feb 2025
    Franklin, ACT
    OBDeleven OBD11 in Canberra
    Hi! I'm in Canberra and recently had to buy a OBDeleven Pro pack to fix a safety issue in my car because VW service weren't 'allowed to' even though they acknowledged the safety fault existed. (Car would randomly not overtake cars in ACC mode when legally overtaking in the right lane.) They even told me I could do it myself with this device. Sigh.
    The Pro subscription is for a year, so if anyone in Canberra needs to fix/change something in their VW/Skoda/Audi, I'm willing to help for a donated shiraz or $20. (It needs to be my app login adding your car to my 'garage', so I won't lend it out.)
    All I'd ask is you do some research and know what in the OBDeleven App (long coding / adaptations) you need to change so we're not starting from scratch and taking a long time - especially with many things being in German!
    Things I changed in my 2022 Skoda: undertaking prevention off / auto rear wiper off / (normal) cruise control option enabled.
    I'm not monitoring this forum, so please PM me.
  5. #455
    Feb 2025
    Montenegro
    Hello everyone. I'm new to the forum, so please forgive me if I posted in the wrong section.
    I have a Passat B7 on which I activated the "rain closing" function, and it works fine.
    To clarify, the car originally had a BCM unit with the part number 3AA937087H, and I replaced it with 3AA937087R to make this function possible.
    The RLS sensor has the part number 1K0 955 559 AH.
    However, now I have a problem – the wipers do not work in automatic mode after activating the "rain closing" function. They only work in manual mode. As soon as I deactivate it in the MFA, everything works fine again.
    Does anyone know what the issue might be and how to fix it?
  6. #456
    Feb 2025
    Montenegro
    Thanks in advance!
  7. #457
    Feb 2025
    Hi, is there anyone in Brisbane familiar with retrofitting a digital gauge cluster into a Mk7 Golf R? Will need coding.
  8. #458
    Quote Originally Posted by Tarantula2344 View Post
    Cant do that just with VCDS, need to sort out component protection as well. which needs ODIS
  9. #459
    @h100vw: Hmm......... with the deepest respect for your view (and with absolutely no offense intended) - the need to deal with CP really depends on how OP plans to "retrofit a digital gauge" on his mk7.
    Yes, if a complete module swap is used - CP becomes an issue immediately after the first ignition switch-ON. However, if OP chooses the product HERE, then no CP (because the basic CAN part of the original module is retained and the analogue clocks are replaced
    So, if OP has an interest, there's a good write-up HERE
  10. #460
    Feb 2025
    Thank you. Dang sounds complicated. I guess I'll stick with analogue dials for now lol
