Hey all - I have an 07 R32 DSG and I'm looking to do the basic settings procedures for DSG and TB, anyone around the Melbourne area willing to help with that? Thinking of pulling the trigger on a Ross Tech but they're pretty pricey.
Hi all
Does anyone in Brisbane area have ODIS I could use to remove component protection for a ACC radar retrofit on a golf mk7 Gti please. I’ll pay in cold cash or cold beer…
Thanks in advance
You can't restore the fec to the radar if it didn't exist in the car to start with.
So you would need to first patch a 3q0 radar offline to defeat CP and install the required licenses.
Sent from my SM-G781B using Tapatalk
Ok mate thanks, sounds like I need to do a bit more research. The hardware side of it sounds easy enough, but nothings ever simple I guess…
1 moment though....if it's a MK7 not 7.5 you can use the older 5Q0 radar which doesn't have FEC...just CP which yes you can remove with ODIS online.
Adaptive Cruise Control retrofit - ACC on MQB - mqb.pl
Thanks mate, that’s what I thought originally. Appreciate you letting me know, the retrofit is now back on the cards…
Can anyone in Melbourne help me with an airbag warning on a Passat B7? It was caused by a low battery after the headlights were left on.
After a jump-start everything seems to be working fine, but the warning hasn't gone away - I believe it needs to be cleared manually?
If you don't mind coming down south I am regularly in Mornington \ Frankston way and always have the VCDS in the car![]()
MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Genuine VCDS HEX-NET and VCP Pro
Hey guys, anyone in the NSW Southern Highlands or Goulburn area that can scan a T5 transporter 2.5 axe, running rough Im in Marulan, can tilt tray to you if necessary..
Cheers Jai
