Can anyone in Sydney help setup my B7 passat with this feature?
How to activate automatic rain sensing wipers feature on a 2012 VW Passat TDI
In Ryde/Strathfield of Sydney NSW -
just need a scan to tell me if somethings up (diagnosing an issue)
Anyone ?! Thanks !
Sorry guys it's a 2006 Mkv gti -
There are "known" issues with the spec A camshaft in the earlier Mkv gti's - mine is one and I have experienced something similar to the symptoms so hence the worry :0)
Just to update I have changed the fuel filter - spark plugs are about 35,000ks old and do need a change. But the car pulls hard 1st / 2nd gear and falls flat at WOT
A scan should help isolate the issue/s
Thanks again , I won't expand upon this as its hijacking this thread !
Now we are talking about the right vehicle... You should log measuring blocks 2 31 99 for fuelling, 3 20 22 for ignition, 3 115 118 for boost, 115 112 and 118 for EGTs and 32 111 at idle to check for intake leaks.
Run the car from 1500 revs in 3rd to the redline if you can.
After a scan I think you'll be much wiser. I am in Sydney next week and might be able to help you, but I have a few others to tune first.
Did you see my email, we have that covered now.
I am pretty sure it's had something else loaded previously. I tell you what, you should try the cruise control and see if it suddenly gets a load of power... Just in case it has APR in there and no one said anything.
Hi everyone, just got a MY12.5 polo gti and want to get 2 codes done. Anyone in sydney free to help out ?
1. turning off warning on the bluetooth unit when it is unplugged (touch adapter)
2. activating auto lock and unlock
